0 members (),
172
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I have pulled the original wiring harness out of my 1950 1/2 ton project. It has been modified and added to and worn thin over the past 58 years, but I believe most of the major components are still there.
Is there any value in this wiring harness or its components? Would I be committing a crime to chuck the whole thing in the garbage or should I put it up on the freebie/for sale board?
Thanks for any advice. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you may wish to keep the little things attached at the ends, like cab inst sockets for one . things like that. other than that how do the wires and insuation look? any discolored copper wires? strip and end or three & see. is the insulation hard? it will crack. if not the wire is probable OK. it's worth alot in china as they've been buying all our copper wire (pacbell) cables for recycle.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
