2 members (John Dlugos, 1 invisible), 150 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#457113 09/30/2008 1:11 AM
My 1949 Chevy 216 is almost ready to roll again after installing new rods and main bearings. I just have a few more questions and really appreciate all the great advice you've given me so far.....
ENGINE:
1. should I prime the oil pump prior to cranking the engine? If so, how is the best accomplished?
2. I plan to use high-tack gasket spray on the head gasket surfaces. Gasket is a FelPro, looks like it's made of metal with a blue coating on both sides. Is this a good idea or should it be installed dry?
3. Should I use gasket spray on the exhaust/intake manifold gaskets?
As always, other advice is also welcome - just want to get this bad boy back in business after chipping away at it for the past couple of months.
49 Truck Nut
49TruckNut,
Here is my two cents. Priming the system is always a 'plus' and can be easily done with the distributor removed. A small drill rotated clockwise can be inserted into the distributor hole. Look at the drive tang on the end of the distributor drive and this is the little doo-dad you will have to replicate to attach to your drill and stick into the female slot in the oil pump.
Most modern head gaskets go on dry. I think the blue coating IS the factory sealant...nothing extra needed.
I have always installed the intake/exhaust gaskets dry. Any sealant here will disappear in nano seconds. This isn't a place for goop or sealer.
Set all your points, plugs timing and carburetor just right and your new engine will fire up on the first couple of cranks. Good luck.
Stuart
