1 members (VicZ), 231 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#45706 06/02/2005 12:59 AM
Where is it and or what is it?
thanks
#45707 06/02/2005 6:40 PM
Junior Member
Junior Member
I suspect that he really means a stuck oil RING. The oil control rings are the bottom ring on each piston. If an engine sits for a long time without being run, there is the possibility of a stuck ring(s). Sometimes, they will free up if the engine is run for a while - sometimes not.
Good Luck.
Doug
54 Chevy 3100
