2 members (tesa, Ponchogl),
50
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45706 06/02/2005 12:59 AM | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | Where is it and or what is it?
thanks | | |
#45707 06/02/2005 6:40 PM | Joined: Mar 2005 Posts: 12 Junior Member | | Junior Member Joined: Mar 2005 Posts: 12 | I suspect that he really means a stuck oil RING. The oil control rings are the bottom ring on each piston. If an engine sits for a long time without being run, there is the possibility of a stuck ring(s). Sometimes, they will free up if the engine is run for a while - sometimes not.
Good Luck.
Doug 54 Chevy 3100
