7 members (Nick in Manitou, 66flea, Cletus1950, Hotrod Lincoln, 2-Ton, Jay R, TooMany2count),
333
7
Mod | | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | The slave cylinder is leaking the last few days on my 1960 c-10 apache, w/ original inline 6 4speed granny trans. LMC list a 1 1/16" bore slave cylinder. Is this the correct part?They also have repair kits w/ 1" or 1 1/16"bores available. Are they talking about the piston inside the slave cylinder? And about bleeding the system after install? any advice would be appreciated need to order parts on Monday.
Thanks Ken | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ken 1960, according to my brake book, from 1960 - 62 a C10 could have had a slave cylinder with a 1" or a 1 1/16" bore. Yes they are talking about the size of the piston inside the slave cylinder. You bleed the slave cylinder in the same way you bleed a brake wheel cylinder, open the bleed screw when the clutch pedal is up, push the clutch pedal to the bottom and hold, close the bleed screw, let the clutch pedal up and begin the process again, until only fluid comes out of the bleed screw, hope that helps. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A repair kit works real good on clutch cyls. They go through a long stroke so there is seldom any pitting or corrosion. Any parts place can get a kit for you at a fraction of the cost of a new cyl. Napa prt # for the 1" #255. For the 1 1/16" #408. Carquest can supply them also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | Right on, I guess I better take it off 1st then over to Napa, it will be a couple days before starting, if I need more help I'll let you know. Tanks again Ken | | |
