1 members (Wooley),
105
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Ron(WE b Old) came down today and gave me a seat back(very badly needed) and other useful stuff, and along with that is the old exhaust system he had before he got the Flow Masters. I just now got done cutting off enough of the old pipe(the part that hadn't rusted off) to put the replacement pipes on. Then I stuck on the pipe that is supposed to lead to the muffler section(the pipes aren't all connected yet) and held it on with the help of a jack and some bailing wire, and fired it up to see what it sounds like. It makes a WORLD of difference, just going from the old pipe that had rusted in half before the muffler just to switch it to the new pipe. I am now contemplating if I even want to put on the mufflers, but considering how loud it will be, I probably will put them on. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I think it would be wise to start out with mufflers anyway.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well, I just now got the first piece on. But now I'm having bigger problems. My door won't close! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It will sure sound louder with the door open!
~Jim
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If the door won't close after you put the exhaust pipe on Jordan then you put the pipe on wrong, it's supposed to go down under the frame not thru the cab and out the door opening. DG
Denny G Sandwich, IL
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | HAHAHA!!!! No, but I got the door latching now, it has something to do with the door pillar/kick panel area. | | |
