1 members (Dusty53), 174 guests, and 4 robots.
Topics128,101
Posts1,056,180
Members48,436
#456650 09/28/2008 6:24 PM
Is the dowl pin the same for the flywheel end on 366 as a 350?
Doing a clutch job & the flywheel was bad as was the clutch pack.
But there is no pin in the crank flange to hold flywheel centered. Will a 350 be the same??
i have a 427 tall deck and it doesn't have the pin either.
Was there a hole for it?
Mine has the hole in the crank & flywheel but no pin.
There should be one in there. Its a hardend pin.
Some one dint put it back in, They come out with the flywheel some times & if its bad & has stress cracks Etc they dont get put back in.
there is a hole in the crank but it doesn't look like it ever had anything in it, it looks cast. the flywheel doesn't have a hole for one. yours is the SAE type bellhousing right?
Right. The flywheel is suposed to be balanced & put on in only one position, Thats why theres a pin. The pin also holds it to the exact place on the crank.
Yours is a stick shift not a automatic?
yep it's a stick.aren't all of the big blocks neutral balance except for the 454 so you shouldn't have to worry about which position the flywheel goes on. the machined neck on the crank holds it centered.
But than why do they put the pin on there, If it dont make no diff what bolt holes you use, why the pin? There wont be a pin.
The flywheel could be put on using any holes you want.
I thought it was balanced to the crank.
I went to a salvage yard & got a 366 flywheel yesterday & it had the pin in it. I got another 366 flywheel about a mounth ago & there was a pin in there to. But you cant get the pin out cause the pan is in the way & it dont work to try & pull it out with a vise grip. So will have to order some.
Wrench Fetcher if your 427 dont have a pin & there is a hole in both the crank & the flywheel I would get one & put it in there there under $2.00 ea.
