| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | LMC sells this stuff (p.13 of the 47-59 catalog), but for the life of me, I can't remember taking "webbing" off the truck ('57 short step) when I it came apart. What the heck is this stuff for and why would I need 30' of it?
Is this related to the substance (sort of a cross between foam and cork) that is stapled between the reinforcement panel and the front fender? If not, what the heck is that substance and what's an acceptable alternative?
TIA, | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It probably is used as an anti-squeek. If so you could use other materials to do the same job.
~Jim
