4 members (Hotrod Lincoln, ShopRag, Southerntruck, 1 invisible), 122 guests, and 5 robots.
Topics128,261
Posts1,058,342
Members48,485
The slave cylinder is leaking the last few days on my 1960 c-10 apache, w/ original inline 6 4speed granny trans. LMC list a 1 1/16" bore slave cylinder. Is this the correct part?They also have repair kits w/ 1" or 1 1/16"bores available. Are they talking about the piston inside the slave cylinder? And about bleeding the system after install? any advice would be appreciated need to order parts on Monday.
Ken
3B Offline
Hy Ken 1960, according to my brake book, from 1960 - 62 a C10 could have had a slave cylinder with a 1" or a 1 1/16" bore. Yes they are talking about the size of the piston inside the slave cylinder. You bleed the slave cylinder in the same way you bleed a brake wheel cylinder, open the bleed screw when the clutch pedal is up, push the clutch pedal to the bottom and hold, close the bleed screw, let the clutch pedal up and begin the process again, until only fluid comes out of the bleed screw, hope that helps.
Riding in the Passing Lane
A repair kit works real good on clutch cyls. They go through a long stroke so there is seldom any pitting or corrosion. Any parts place can get a kit for you at a fraction of the cost of a new cyl. Napa prt # for the 1" #255. For the 1 1/16" #408. Carquest can supply them also.
1972 Chevy c10 Cheyenne Super
Right on, I guess I better take it off 1st then over to Napa, it will be a couple days before starting, if I need more help I'll let you know.
Tanks again Ken
