2 members (Leo, GRNHydra), 84 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
Hi foks
I would need some help to identify my rear end to be able to get parts for it. What Year? What Car?
I drive it in my 55 1'st serie Pickup 1/2 Ton with a 350/350
GM, 12 Bolt Diff cap, 6 Lug Wheels, Diff casting 3896839, Brake pads are about 2 3/4 wide and the drumms have ribs
Hope that someone can help me with that because it's not easy to find someone in Germany to figure that out.
Just from the description, it sounds like it's from a '73-'77 Chevy 1/2 ton 4x4.
Bill Burmeister
the only thing i can see is 65-67 1/2 ton
The '65-'67 used narrower brake shoes and didn't have the finned drums. The finned drums came later, as did the wider brake friction.
Bill Burmeister
Thanks, I hope that will help me to get some parts.
How wide is the rear end from a 73-77 Chevy 1/2 4X4 ?
I could mesure that too to get closer to where it came out of
According to the spec book, it's 62 3/4" measuring from drum to drum on the outside.
Bill Burmeister
As fare as Brake parts, Brakecylinders and Drumms I think I found the right parts for my rear end but the Part Dealer offers 2 different Diff. Seals (the one that points to the transmission) depending if it is a 1975 K20 1/2 Ton or a 1976 K20 1/2 Ton.
If I order it wrong, it's always a hussle
Again the Diff cast number is 3896839 N
12 Bolt/6Bolt rear end
Could someone help me?????
I got my part's today, everything seems to fit (brakepads, Zylinder and Drums, though the new ones have a little shorter finns but the dimension are the same)just the gasket from the diff cover doesn't mach up. It has 12 holes but the form ist differnt.
How many different 12bolt cover are existing??
I ordert everything from a 1975 k10 1/2 Ton 350, means that my rear end came out of a differnt Truck/Car???? (mine has 30 splines axels)
I don't know if the diff seal / driveshaft will fit, have to take it apart on this weekend.
I appreciate any help with that....
The gasket should be the same for all years of truck 12 bolt. Passenger 12 bolt has a different case, and also never came in 6 lug.
Here is a pic if the truck 12 bolt gasket shape. For comparison, this is the passenger car version. From what I can tell, the seals are the same for all years.
Bill Burmeister
