| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 22 Apprentice | | Apprentice Joined: Aug 2008 Posts: 22 | I'm continuing the rebuild on my 55.1 chevy pickup with a hydramatic tranny. I found 1 broken spring in the dampner hub on the torus cover of the hydramatic. Some of the other springs seem loose too, although they appear to be equal size across from each other. Does someone have a torus cover that they can look at and tell me if those springs are different sizes, and if the broken one can be replaced or do I have to look for another cover. | | | | | Joined: Aug 2008 Posts: 22 Apprentice | | Apprentice Joined: Aug 2008 Posts: 22 | Thanks Greg, the pix are very helpful. It appears that the springs are different sizes but equal size across from each other. This probably is to involve more springs to dampen the effect of increased torque. I'm going to try a machinist friend to see if his company can manufacture a new spring. Unless you know someone who sells these springs. My torus cover neck looks great on the inside, but has a small groove on the outside. The new oil seal seals tight though | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | lil' buffalo,
Just a thought. McMaster-Carr has hundreds of "die springs". If you go to there site and search for die springs, you can select from a plethora of items by OD, length and wire size. You might just get lucky, and they're cheap!
Stuart | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Give these guys a call. http://www.fatsco.com/index.htmThey've been in the antique transmission business for at least 40 years, and they know what they're talking about. They've probably got exactly what you need right on the shelf. I've been doing business with them for 20 years or so, and the only problem I've got is trying to understand the damyankee accent of the guys on the phone! Jerry
