3 members (Otto Skorzeny, DennisM, 1 invisible),
140
Mod | | | Forums66 Topics128,281 Posts1,058,461 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | Is the dowl pin the same for the flywheel end on 366 as a 350? Doing a clutch job & the flywheel was bad as was the clutch pack. But there is no pin in the crank flange to hold flywheel centered. Will a 350 be the same??
| | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i have a 427 tall deck and it doesn't have the pin either. | | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | Was there a hole for it? Mine has the hole in the crank & flywheel but no pin. There should be one in there. Its a hardend pin. Some one dint put it back in, They come out with the flywheel some times & if its bad & has stress cracks Etc they dont get put back in. | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | there is a hole in the crank but it doesn't look like it ever had anything in it, it looks cast. the flywheel doesn't have a hole for one. yours is the SAE type bellhousing right? | | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | Right. The flywheel is suposed to be balanced & put on in only one position, Thats why theres a pin. The pin also holds it to the exact place on the crank. Yours is a stick shift not a automatic? | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | yep it's a stick.aren't all of the big blocks neutral balance except for the 454 so you shouldn't have to worry about which position the flywheel goes on. the machined neck on the crank holds it centered. | | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | But than why do they put the pin on there, If it dont make no diff what bolt holes you use, why the pin? There wont be a pin. The flywheel could be put on using any holes you want. I thought it was balanced to the crank. | | | | | Joined: Dec 2006 Posts: 75 New Guy | | New Guy Joined: Dec 2006 Posts: 75 | I went to a salvage yard & got a 366 flywheel yesterday & it had the pin in it. I got another 366 flywheel about a mounth ago & there was a pin in there to. But you cant get the pin out cause the pan is in the way & it dont work to try & pull it out with a vise grip. So will have to order some. Wrench Fetcher if your 427 dont have a pin & there is a hole in both the crank & the flywheel I would get one & put it in there there under $2.00 ea. | | |
