3 members (delky, Hotrod Lincoln, Rich'sToys), 78 guests, and 0 robots.
Topics128,049
Posts1,055,740
#456490 09/28/2008 12:33 AM
I'm rebuilding a 59 and installing a 350 using the original front mounts. I started to install the front brackets and they hit the harmonic balancer. Are there different balancers, or do I need different mounts? Thank's for any help.
Mike
3B Offline
Hy martinmikey, There are different balancer diameters, and the heavy duty/high performance ones are the largest. Unfortunately there is only one type of O.E.M. mount, you should be able to trim it back sufficiently to clear, but reinforce it if you remove a lot of material, hope that helps
3B #456609 09/28/2008 3:19 PM
Riding in the Passing Lane
Ive run into that also using the large damper. I wacked a little out of them & it worked fine.
1972 Chevy c10 Cheyenne Super
