| | | Forums66 Topics128,060 Posts1,055,832 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | I'm rebuilding a 59 and installing a 350 using the original front mounts. I started to install the front brackets and they hit the harmonic balancer. Are there different balancers, or do I need different mounts? Thank's for any help. Mike | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy martinmikey, There are different balancer diameters, and the heavy duty/high performance ones are the largest. Unfortunately there is only one type of O.E.M. mount, you should be able to trim it back sufficiently to clear, but reinforce it if you remove a lot of material, hope that helps | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive run into that also using the large damper. I wacked a little out of them & it worked fine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
