| | | Forums66 Topics128,100 Posts1,056,510 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 34 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 34 | I am running a relatively stock 292, with the exception of upgraded ignition, a 194ci head (60.5cc combustion chamber), and Langdon exhaust manifolds.
Hoping to run the 2x1 offy intake I have. Wondering if anybody has any carb suggestions for this setup. I have two remanufactured rochester mono-jets, but they seem large and clunky. I'm after a nice clean, simple look. Hoping to run the 1940's chevy truck air cleaners.
I have been considering swapping the mono-jets for a pair of Carters (W-1, 5BR-1, or BB), or perhaps early rochester 1bbl carbs. Perhaps using adapters to use Ford 94 2bbl carbs.
Any suggestions? Thanks | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Check out the Holley 847, it is a nice looking carb. It is the one barrel version of the Holley 94 two barrel used on the ford flatheads.
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | A little trick for your ignition: a 250 electronic dist. drops right in a 292. I have done it, works like a charm. Steve | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I would go with a pair of 2 bbl carbs. The singles won't flow enough to allow the maximum from the 292, especially if you have a healthy camshaft.
Fred 52 3600 69 C-10
