ok im fixing to sawp out my 57 chevy trucks 235 for a built built 75 model 350 engine and i got all my swapping parts v8 bell housing , v8 manuel flywheel etc, and im ording the bolt in engine v8 cross member that truckand car shop offers to mouth the 350 and all . heres my question it looks like it will work or would it be a good idea id like to still use the original radiator that was for the 235 sence it was operating ok before i removed the 235 cause it all ran good and etc can i still use that 235 radiator for the 350????? looks like the water ports is still correct for the 350 but i was told i would or would be a good idea to out a shoud on it for the 350 will this wrok ???? the 235 radiator that is ????? any one done this if not what other chevy truck radiaors will work in the 57 ????
