7 members (Jays58, tricordati, Otto Skorzeny, KEVINSKI, Gazz, JW51, Shade Baby), 147 guests, and 3 robots.
Topics128,095
Posts1,056,468
Members48,444
Junior Member
Junior Member
I found a ring and pinion set that were out of a 69 half ton. It is a 3.73 twelve bolt set. I have read the archieves and found that some chevy 12 bolt rears had this ratio. will this work in a 54 3/4 ton 12 bolt rear? Do I need the carrier from the newer truck or can I make these work with the 54 carrier?
I believe you can swap the pumpkin from a later model into your truck but it has to come from a 3/4 ton. I dont think you can use a 1/2 ton. Others who know more about this than me(almost everyone) may answer your question better.
Good luck.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore is correct. The 1/2 ton pumkin won't interchange with the 3/4 ton. A 67-72 3/4 ton pumkin will swap into your rear end. The best ratio is 410, usually found in a truck with an automatic transmission.
