| | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Im looking to pull a utility trailer behind my truck. Has anyone modified a receiver to fit a 1/2 ton? I have the chrome rear bumper. Was gonna go to the junkyard and find one that would work after a little modification. Any suggestions out there? | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | you could just make one yourself they are pretty easy. just use real heavy channel to go around frame and between. weld the receiver tube where it comes out just below the bumper. you can make one 5 times stronger than any one you could purchase. most will be under the bed so you will only see receiver tube as long as your welds are good no problem. you can use grade 8 bolts i like 3 bolts thru side and 1 thru bottom but that's prob overkill. | | |
