| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | Tell what you think.......... I need a radiator for "The Big Dawg" 48 3100 shortbox. Running a 350 with a 700 r4. I am using the stock radiator support. Would like to use an aluminum radiator. Here's the $20,000 question? What radiator did you use and who did you get it from? How much? Tom http://rides.webshots.com/album/549600140EXoKSz
48 Chevy 3100 Shortbox 5 window "The Big Dog"
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have seen several folks use a stock 1.5 or 2 ton AD radiator in a 1/2 ton with 350, and they say it works great. The big truck radiator core is approximately 2.5" thick, I'll go measure exactly if you are interested? It also bolts in just the same as a small truck radiator.
If that works for you, my original, with a 48 date stamp, could be available, send me a PM if you are interested. Because I have a feeling I'll need the aluminum one, I'm looking at the Griffin aluminum ones that are supposed to be a mostly original looking (other than the aluminum part) bolt in deal.
Grigg
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I think the Griffin is around $600 or $700 from Summit.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | I priced a new Griffin 2 core with 1 1/4" tubes in a 2 3/4" thick core for my 51 gmc 1 ton flat bed for $640.00. I am also trying to determine the best radiator for my truck build. I am running a little different setup, I have a 454 with the four speed. I had to call the number on the website in order to get info. The website is www.griffinrad.com. Maybe this will help. I have never used one these radiators before, I am hoping to get feed back from this forum. I have also priced radiators from US Radiator and Jim Carter's that are more the traditional style radiator, I want to make certain that the engine will stay cool. Good luck with your search Tomy2tone01. | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | dsmith do you have any pictures of your truck? I'm putting a 454 in a AD 2 ton | | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | I do. I am trying to figure out how to post them. I will try to set something up and post a new thread under the Welcome Center. I don't want to steel Tomy2tone01's thread. Keep a watch there. | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | Had a local radiator shop do mine, the tranny builder wouldn't warranty the tranny without some very specific radiator requirements. It was $450. Towards the end of my 350 installation saga are pics of it. Ed | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Ricos Rods And Relics in the links section seems to have good prices on radiators and a decent selection. Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
