4 members (Maybellene, J Lucas, Otto Skorzeny, Leo), 66 guests, and 3 robots.
Topics128,057
Posts1,055,808
#453176 09/17/2008 6:34 AM
Hi folks.. I just bought a 1954 gmc 1 ton model 9434 (canadian). When I got it the battery was hooked up negative ground. The truck runs fine this way. Is it supposed to be positive ground? I have had no experience with positive ground so I'm not sure. Thanks for any input. Ward
Elwardo
Which way does your ammeter show when it is running? Canada GMC's were more like US Chev and could well have a negative ground.
thanks . I will check out the ammeter reading... ward
Elwardo
Ok I started it up and the ammeter is pointing to C . So I assume that it is a negative ground system then?
Elwardo
If it's got a Delco regulator, copy down the part number stamped on it. I can cross-reference a part number to tell if the system was originally positive or negative ground, assuming it's got an original-equipment regulator on it. If it's not a Delco unit, my reference books probably won't be much help.
thanks i' ll get the number.. ward
Elwardo
