2 members (MNSmith, Lostbuthaulinass), 105 guests, and 1 robot.
Topics128,057
Posts1,055,814
#455527 09/24/2008 12:26 PM
My generator is going out...would it be better to rebuild it or convert to 12v? Do I have to replace the wiring if I go to 12V? Are there any conversion kits out there?
If you are happy with your six volt system and just need to repair it then "Stay the Course". If upgrades are necessary or desired such as A/C then converting to 12v is for you.
Ex Hall Monitor
Ex Hall Monitor
Unless you're wanting to run 12v accessories there's no reason to convert to 12v. A mechanically sound and well grounded 6v system is more than adequate.
Based on other responses, this is a minority report. Unless you are attempting to keep the vehicle stock for show reasons for instance, I believe in converting to 12v for the right reasons, and one of those would be not dumping a dime into a 6v generator. 12v. is easier to start in the winter, is more forgiving if you don't have all the connections clean, bright, and tight (like most of us), and you don't have to search around for 6v. accessories and light bulbs. The wiring on a 6v. is generally heavier than 12v., so you won't have to change that. Changing over is somewhat complicated, but maybe there is a 12v. conversion kit for you in the market place ?
