2 members (Otto Skorzeny, baldeagle), 118 guests, and 2 robots.
Topics128,037
Posts1,055,467
Members48,424
#455253 09/23/2008 5:52 PM
V
V Offline
In case anyone is in a similar situation as I was...
I put a camaro rear into my truck and was looking to use the 2.5" width camaro leafs as well. Problem was in finding some mounts to bolt the springs to the frame. I thought that unversal leaf spring mounts would be something of a common part, but they actually were difficult to find. Ended up finding with and buying them from a company Warrior who makes offroading parts. Drilled the frame and they bolted in great for mounting the leafs themselves but were not wide enough to account for the massively wide camaro stock bushings. So next step was to turn some new urythane bushing to fit.
Apprentice
Apprentice
I use Crysler 5th ave spring mounts....Don
Don Meyer - Mech Engr(retired)
48 GMV
66 RR
64 Corvair
What year truck frame are you using? Is it 1/2 ton?
V
V Offline
my truck is a '49 1/2 ton. For shackles, I reused the originals and I will will a small block to lower it a bit more. If anyone needs, I can post the eyelit distance from front to rear mounts and/ or distance some a rivet or some other reference spot. Definite time savers or at the very least, quality control checks.
Hi vik morgan - yeah it would be helpful if you could post the measurements.Thanks.
