10 members (Bill Hanlon, TooMany2count, 66flea, Hotrod Lincoln, BC59, Charles in CA, Gdads51, 68ironhead, 2 invisible),
93
Mod | | | Forums66 Topics128,032 Posts1,055,519 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | I just bought a Hamilton lathe and I need to make a phase converter but I have never done this before. here is the info I have. 220 v 3 phase 3hp motor.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I have not hooked up my rotary phase converter, but in checking the different ones available on line, I found the wood working sites had the best information on them. It is best to purchase a rotary phase generator if you have the cash, otherwise the option I took is ok.
I purchased a phase converter that uses a 3 phase motor to convert single phase to three phase. make sure you size your three phase motor to a larger motor. I have a five horsepower load and I am using a seven and a half horsepower motor to turn it with my phase converter.
Using the type that I purchased will result in some imbalance, but since I am not going to be using my woodworking tools constantly, I chose this route over the much better rotary phase generator. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I built a pony start 5 hp for abut $30. Theirs plenty of info on the web for about any kind of converter you would want to build. The one I built will run my Bridgeport mill and a old 3 hp horizontal mill at the same time with ease. My biggest expense was wire and boxes old three phase motors can be had for scrap prices. Don't be tempted to use a static converter most gear head lathes without a clutch start realy hard. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | For hobby use a static converter works just fine. | | | | | Joined: Sep 2008 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 87 | I would like to run the end mill and the lathe together | | |
