| | | Forums66 Topics128,097 Posts1,056,495 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 54 | I'm at the point with my rebuild of putting in the exhaust and mufflers. Engine is Chevy 6-cylinder 235 with Fenton Dual Intake and Headers. Looking to get an aggressive tone but not sure about what pipe size and brand of muffler would be best choice. I've had some buddies in my local car club that said that I may want to keep the pipe size to 2" or less to assist with backpressure modulation. Any/all feedback would be greatly appreciated. I was initially planning to use FlowMaster Series 40 mufflers with 2" pipe. I'm going to run the pipe straight back through the rollpan that I've installed. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | All depends on what you want in the end. Are you going to run your headers into a single or run dual pipes? If dual, will you run a crossover pipe between them? For a classic sound, my preference on old trucks, I would run 1 3/4 dual pipe, short glasspacks and no crossover. For a more modern sound you could go with a pair of flowmasters, still keep the pipe small and use a crossover pipe, or if you want a single go with 2 1/2 pipe and a modern muffler of your choice ( i like Borla myself)
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | 55 tractor has it right, 1 3/4" pipes and straight through mufflers, probably glasspacks will give the best sound, but it will probably be pretty loud, but some of us old guys like that. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Did the guys in the club tell you where the most skilled/experienced pipe bender in town works? Go visit him and compare his opinion to what you find out here. I went with 2" straight out the back and Dynomax mufflers as was suggested to me.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I also run 2 inch all the way. Cleon | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm running 2" also, with Walker Jeep mufflers.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Ditto on the 1-7/8ID-2"OD pipes. No sense of dumping your low-end torque. As for the FlowMasters.....don't think they make them down that small. I had a pair of 40's that I reduced down to work on the 2"OD pipes. Didn't like the tinny sound so went back to the Cherry bomb glass packs. Nice and mellow up to 2300 and then they make that unforgetable inline 6 "chaingun" sound...no crossover.
Dave | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Take a look at my setup in the photolink below. Used a one in/two out single muffler. Isn't very loud but does soes sond cool. It's 1-7/8 from the Fenton to the custom collector and 2" out the back of the muffler. It offers just enough back pressure but gives a decent sound with the right muffler. I replaced the muffler to a stock type because it's my wife's truck and she likes it quiter than I do.
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Lots of studies comfirm that ideal pipes for these 216 to 235 ci engines for backpressure and gas mileage work best with under 2" pipes, 1+5/8 to 1+3/4" ideal if you can find the pipe. And place your mufflers back as far as you can without crossover. I like the brockman mellotones steelpack mufflers, you can get them made any length. Have also used smittys, borla, flowmasters, jeep etc.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i would think 1-3/4 to 1-7/8'' for backpressure. your muffler shop guys do this ALL the time. They should know if you go to an older shop w/ experienced techs. i have a mildly hot 292ci and run 2' twin split 3+3 to a single quiet #50 walker to a 2-1/2'' out tail pipe. muff well under the bed. http://www.walkerexhaust.com/support/exhaust101/inspections.asphttp://www.walkerexhaust.com/support/exhaust101/systemBasics.asphttp://www.walkerexhaust.com/support/exhaust101/productsOfCombustion.aspit's a hard answer as many will say what's best and you may want a loud (rap~rap) or quiet muffler. if the actual muff is placed directly under the cab you're in or lots o noise as well as down the road exh. issues in the cab, so placement is a thought. That's ALL up to what you want.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
