8 members (HandyAndy, Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series),
72
7
Mod | | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45506 01/12/2005 3:12 PM | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | I ripped the engine out of the 52' this weekend. Pulled the heads and found the pistons are stamped with 0.040" and the tops are pitted but not real bad I can still read the 0.040". The piston walls look good. I drained the oil and am going to pull the oil pan and check out the crank. So all in all it was a good weekend. I did find 2 broken push rods. So I have a question, can and where can you purchase just 2 or a set of push rods for my babbit pounder? any comments on if i need to check out something i did not mention, sense the engine is pulled will be greatly appreciated. Oh yea when I pulled the clutch and flywheel, the flywheel had heat cracks in it from the clutch, can you machine this out if it is not too deep or is it best to buy a new one and where should I buy from? thanks in advance.
Get busy liv'n or get busy die'n
#45507 01/12/2005 11:06 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The push rods are available individually at most pro type auto stores like Carquest or Napa. The next thing to check are the rod bearings. If they are in good condition & have some shims left you can adjust em & go on. Otherwise you will need to get them rebabited on converted to inserts. The fly wheel can be surfaced ground & used with lightcracks (we,ll get debate on this) I,ve done it many times.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#45508 01/13/2005 4:45 PM | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | Thanks for the response, I was getting a little worried. I will post on my findings and as always thanks for the help and paticece (and spelling) on my first frame off restoration.The cab will be the next to go and then I will get working on the rolling chasis.
