I am going to swap a 76 front end into my 70 1/2 ton 2wd c-10 so I can have power steering and disk brakes. Looks like it should slip right in but my question is the master cylinder and power booster. Will that bolt right to the firewall with little problems? The bolt pattern is a little different it looks like, booster to firewall.Is the push rod from cab to booster going to work? eek Has anyone done this swap?
