| | | Forums66 Topics128,023 Posts1,055,371 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45483 10/24/2003 10:45 PM | Joined: Oct 2003 Posts: 1 Junior Member | | Junior Member Joined: Oct 2003 Posts: 1 | I am searching Junk yards for a 235. The yards tell me it would be much easier to identify the engine I need if I had a case #. Can any one give me what they need to check their inventories? | | |
#45484 10/24/2003 11:05 PM | Joined: Jan 2002 Posts: 19 Member | | Member Joined: Jan 2002 Posts: 19 | John You will find block # at inliners.org. Dave | | |
#45485 10/25/2003 1:12 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | You will want one that is '54 or newer. Better yet, find a 261 from a larger truck or schoolbus. It is the same engine only more hp.
54 3100 with 235 62 flatbed dump C60 with 261
#45486 10/25/2003 3:33 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Hi- this article from Patricks has stuff in it you might be intrested in. This is also in thier catalog. Very friendly people F. Want to pinpoint engine I.D.? On the block above the end of the starter will be an initial (A-L), followed by either (2) or (3) numbers. The initial represents the month: the numbers are the day and year the block was cast. Now, then, no more guessing! http://www.chevrolet.com.au/articles/engine_swap.htm http://www.patricksantiquecars.com/ Good luck. Brent | | |
