3 members (2-Ton, Mike B, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,419
Members48,422
#45483 10/24/2003 10:45 PM
Junior Member
Junior Member
I am searching Junk yards for a 235. The yards tell me it would be much easier to identify the engine I need if I had a case #. Can any one give me what they need to check their inventories?
#45484 10/24/2003 11:05 PM
John You will find block # at inliners.org. Dave
#45485 10/25/2003 1:12 AM
You will want one that is '54 or newer. Better yet, find a 261 from a larger truck or schoolbus. It is the same engine only more hp.
54 3100 with 235
62 flatbed dump C60 with 261
#45486 10/25/2003 3:33 AM
Hi- this article from Patricks has stuff in it you might be intrested in. This is also in thier catalog. Very friendly people
F. Want to pinpoint engine I.D.? On the block above the end of the starter will be an initial (A-L), followed by either (2) or (3) numbers. The initial represents the month: the numbers are the day and year the block was cast. Now, then, no more guessing!
http://www.chevrolet.com.au/articles/engine_swap.htm
http://www.patricksantiquecars.com/
Good luck.
Brent
