0 members (), 140 guests, and 0 robots.
Topics128,260
Posts1,058,343
Members48,485
#454664 09/21/2008 11:15 PM
Riding in the Passing Lane
My headlights work fine on HiBeam, but not at all on LowBeam.
Is it the switch, the headlamps, or both?
The truck was completely re-wired a couple of years ago, so I don't suspect the wires to be a problem, I don't guess.
~ davey
1967 Chevrolet 1/2-Ton Pickup
I'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.
I've forgotten more than I ever knew. Okay, where did I put it?
A man can never have enough tools
Lovett #454680 09/21/2008 11:52 PM
The problem is usually the dimmer switch or the connector. They are in a horrible invironment. It,s possible both bulbs are burned out or the connectors are corroded but it is more likely the dimmer switch.
1972 Chevy c10 Cheyenne Super
Lovett #454681 09/21/2008 11:54 PM
My guess is you need new headlamps or your dimmer switch conections cleaned up. It is easy to check with a test light for power through the dimmer and at the lamps.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
gtow69 #454683 09/21/2008 11:56 PM
You type faster then me Wrenchbender Ret, but we are on the same trail!!!
Wanted Good Woman:
gtow69 #454700 09/22/2008 12:42 AM
Thanks! That's what I figured it was. I think I can fix this problem myself instead of paying someone else to do it.
~ davey
Lovett #454960 09/22/2008 9:52 PM
Thats right Davey. Thats what this hobby & these old trucks are all about, fixing as much as you can yourself & knowing your limitations.
I just had a similar problem. No bright lights. Replacement harness had a 3 pin plug connector from the dimmer switch. Power/high/low. Traced the problem to this. Pulled it apart and found the pins inside the connectors were not making contact for the high beams. Pushed pins in farther on both halves of connector to be the same as the other two. Plugged it back together and now they work fine. Might not hurt to look.
Good luck,
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #455314 09/23/2008 10:13 PM
well.........
Redryder pix
My Hotrod
