8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible), 99 guests, and 7 robots.
Topics128,264
Posts1,058,358
Members48,485
#454665 09/21/2008 11:20 PM
Riding in the Passing Lane
When I bought the truck, it had a Tach mounted on the steering column. When I had to have the truck re-wired, I asked David to leave the Tach disconnected.
I am now thinking of hooking the Tach up myself, but don't know how to wire it correctly.
Any help will be appreciated.
~ davey
1967 Chevrolet 1/2-Ton Pickup
I'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.
I've forgotten more than I ever knew. Okay, where did I put it?
A man can never have enough tools
Lovett #454679 09/21/2008 11:48 PM
You probably have 4 wires comeing out. You will need a way to identify them. One goes to the hot side of the ign switch when you turn the key on. You can hook it up at the fuse box. One goes to the neg. side of the coil or the Tach. term. on HEI. One goes to the dash lights (usually grey). One is grounded (usually black).
1972 Chevy c10 Cheyenne Super
Thanks, I'll take a look at the wires soon as possible.
~ davey
