| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45436 01/17/2005 9:47 PM | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Does the glass bowl on the fuel filter need to be pointing up or down...or does it even matter? Thanks. | | |
#45438 01/18/2005 10:49 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I have mine pointing upwards and the slosh collects on the buttom, no problems so far, so I think it doesn`t realy mather. [img] http://www.thesavoy.de/assets/images/Carbdetail.jpg[/img] | | |
#45439 01/18/2005 2:56 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Ideally you want it pointing up as the small amount of air left in the bowl will help to regulate the pressure.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#45440 01/18/2005 4:37 PM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | I have to agree with Joe. What's heavier; water or gas?
Gord 1954 1/2 ton 235 4 speed
#45441 01/18/2005 8:12 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It depends on the model Most are made to mount bowl down. The ones on the pump are made for bowl up. If in doubt, check the manufacturer's instructions.
Fred 52 3600 69 C-10
