1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 18 New Guy | | New Guy Joined: Aug 2008 Posts: 18 | Ok, I now finally have brakes!!!!But something else strange is happening.As I just bairly touch the brake pedal I look down at the cap thats on the master cyl.(there are 2 little holes drilled at the base of the square head.) and a combonation of brake fluid and air is coming out.Do I have the fluid level too high or are the grimlins at it again(messin with my head). | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | no signs of a hole on the old master cylinder cap off my 38. The new one has a small hole in the side of the plastic cap but i couldn't see if it was from the molding process or a thru haven't had fluid in it yet. The fifty four has a regular pipe plug in it no holes may not be orignal type. | | | | | Joined: Aug 2008 Posts: 18 New Guy | | New Guy Joined: Aug 2008 Posts: 18 | I got this new master cyl form jim carter last week.Maybe I should try there Tech and see if he knowes anything about it.Can't seem to find the Old cap to see if it has holes. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | For what it is worth, my 52 has holes in the M/C cap. It also has a shield on the underneath side to deflect the brake fluid back in to master cyl when you hit the brakes. There was a thread some time ago that explained why you need atmosphereic pressure to the fluid. Try a search in the archives you will find more info. | | |
