3 members (Otto Skorzeny, mason86, Gray_Ghost), 110 guests, and 2 robots.
Topics128,069
Posts1,055,890
Members48,428
#454329 09/20/2008 12:53 PM
Ok, I now finally have brakes!!!!But something else strange is happening.As I just bairly touch the brake pedal I look down at the cap thats on the master cyl.(there are 2 little holes drilled at the base of the square head.) and a combonation of brake fluid and air is coming out.Do I have the fluid level too high or are the grimlins at it again(messin with my head).
no signs of a hole on the old master cylinder cap off my 38. The new one has a small hole in the side of the plastic cap but i couldn't see if it was from the molding process or a thru haven't had fluid in it yet. The fifty four has a regular pipe plug in it no holes may not be orignal type.
I got this new master cyl form jim carter last week.Maybe I should try there Tech and see if he knowes anything about it.Can't seem to find the Old cap to see if it has holes.
For what it is worth, my 52 has holes in the M/C cap. It also has a shield on the underneath side to deflect the brake fluid back in to master cyl when you hit the brakes. There was a thread some time ago that explained why you need atmosphereic pressure to the fluid. Try a search in the archives you will find more info.
