5 members (J Lucas, Lugnutz, Otto Skorzeny, Steelonsteel, Rich'sToys), 94 guests, and 2 robots.
Topics128,211
Posts1,057,472
Members48,473
Junior Member
Junior Member
I have been working on a 51' chevy 3100 for the last year and Im working on replaceing the old inline 6 for a v8. the problem is that I don't know what is the best way to preform this job I heard that you could slap on a camero,monte carlo or a 1964 nova front end clip. Well all of this sounds pertty cool but how do I know wich is the best way.
:confused: :confused:
None of those front end changes just slap on grin .
You have already taken the first step: ASK QUESTIONS.
Go to this site http://50chevy.freeservers.com/topics.htm#Topics
He has information in there about Camaro Subframes, Mustang II, Chevy 1/2ton suspensions and even Pacer Independent suspensions. Read, through these areas, maybe they will give you an idea of the work involved.
They all can be accomplished along with rebuilding the front end that is presently on the truck.
You really, have to do some reading so that you are sure which way you would like to go and the capabilities you have either financially, or talent wise, to accomplish the task.
I have found nothing is ever quite as easy or as difficult as it appears, but usually, things end up costing more than it first appears.
Just try to get your facts together, plan ahead and just don't haphazardly start tearing things apart.
Good luck with your project.
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
Chev 51-
Welcome to the Stovebolt. Your question is one many of have pondered and I suspect you'll hear a range of responses. To drop in a Chevy V8 does not require a front clip, but alteration of the engine mounts and transmission mounts. You may want to switch transmissions and rear ends while you're doing this swap. Some further choose to drop the entire drivetrain from a donor vehicle into the truck. If you're committed to the V8, this is a straighforward swap. A full drivetrain swap will give you power and less vibration at highway speeds.
Owning a '51 as well, I pondered the spectrum of choices and opted to go with a new front clip. For me, I wanted to gain better front suspension and power steering. I'll enjoy the smoother ride over bumps and the misses in my house will have an easier time getting the steering wheel around. I knew that it was a much bigger can of worm$$ to open and it would take longer to get on the road.
So in the end, you can choose to drop in the V8 and call it good, getting you right on the road. It's much more work, but you can choose to graft on a front clip and/or switch to a modern drivetrain. Other components could be added later, after you've had a chance ot get a feel for the truck. Think carefully about the time and expense. The choice is yours. There are some good tech articles here you should read as well.
The good news is that you've come to the right place for advice (and jokes and politics...). Folks here at the 'Bolt will keep you rolling and freely offer their expert experience. We look forward to hearing more about you decision and progress!
