3 members (tesa, Bill Hanlon, Gray_Ghost), 76 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
Before I start pulling and trying to unscrew something that shouldn't be, how do you get the knob and steel shaft out of the headlight switch so I can put in a new switch ? Does the knob unscrew, and if it does, then how does the steel shaft come out of the switch ?
thanks in advance.
I dont know about yours, but mine has a button on one side that is pushed in and releases the knob/shaft. Its a '57, but maybe yours is the same. Hope this helps.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
