5 members (Bill Hanlon, Joe H, Otto Skorzeny, Gdads51, 3B), 157 guests, and 4 robots.
Topics128,110
Posts1,056,246
Members48,437
I pulled the block & tranny out of my truck this past weekend, but I wimped out and waited until the temp hit 12 above in my unheated garage. I'm pretty sure they come out faster at that temperature and the only problem I had was the temporary freezing of my nose to the fender when I was reaching for one of the radiator support bolts under the fender. Kind of reminds me back in the school days when you'd wait for a good cold day(under 15 F) and try to trick the new kid at the bus stop into licking their finger and touching a stop sign post or something metal - always good for a laugh. Gotta have fun with that cold weather.
Now for the problem, I got the block all stripped and can't get the Harmonic balancer off.
I made up a puller with a 1/2" center bolt tapped thru a 1/2" steel plate and the two 3/8" bolts screwed into the pulley. I even ground a point on the end of the 1/2" bolt, but the thing won't budge.
I'm just using a grade 3 bolt and it feels like I might twist it off. I don't care about my puller, but I don't want to damage the Harmonic balancer or crank, any tips ? (other than heat it up?)
Oly Offline
Sounds like you may have the right idea going there. Just heat the center area up good and get a BFhammer and whack the end of your bolt a good one or two. Make sure you have your finger on the end of the bolt to hold it in place.
ps
Did you get my email about where you could get a "good head"?
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
Oly,
I did not get your email, try it again.
Well (mainer) talk about cold.. here in Northern
Ontario our local weather station reported a
wind chill factor of -41 degrees..I think I'm
head'n back to bed..
1946 chevy 1/2 ton panel
1937 ford coupe
