0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 47 | Hi. I need some more advice on my 1949 Chevy 3/4 Ton truck project...
I just picked up my 261 from the engine shop and it looks like I goofed on the harmonic balancer. I must have given them a newer one from a 235 that has a skinny belt groove instead of the '49 wide belt groove. The original '49 216 water pump was installed using an adapter plate on the front of the 261. The '49 water pump pulley is the short style with the wide belt groove. The bottom line is that the centerlines of the fan belt grooves do not line up.
Surely someone has run across this before. Am I better off to change the water pump pully or the harmonic balancer?
Thanks! Dan M. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dan,
It would be easier to change the harmonic balancer. What width groove do you have on the generator pulley? It should match the other two pulleys.
Tim | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think the '54 car water pump has a skinny grove, that may work.
