0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 37 New Guy | | New Guy Joined: Aug 2005 Posts: 37 | I've been trying to determine if the pistons from my '49 Chevy with 216 engine are marked in any way to indicate orientation. I understand that the connecting rod casting numbers face the front of the engine and that the oil dippers are installed with open faces towards the cam shaft. After conditioning the cylinders and installing new piston rings it's time to install the new rod/piston assemblies. I'm just not 100% sure about the original pistons orientation. I suspect that this old engine does not have a particular piston orientation but need to be sure. Apart from the 0.030" oversize stamping on the piston head I do not see any orientation markings.
49 Truck Nut
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I just checked a set of used '50 216 pistons and I also see no orientation mark. A quick check of my shop manual also didn't indicate any positioning other then centering on the rod.If it's not mentioned and someone's experience doesn't indicate it I think you can assume the piston mount to rod is non-directional.I suppose that's a good reason to place a mark on disassembly.
Drew
