| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | I have been working on my 1946 chevy pickup with a 216 straight six. It looked like I was having coil problems (no spark) so I replaced the original with a mail order one from Jim Carters. The one I received in the mail looks abit different. The one that was on the truck had two connections. One connected to the ignition lock that went under a cap on the coil. The other went to the distributer on the engine. The mail order one has no cap that removes but it has a positive and negative post. I'm sure this is an updated version of the one that I need. Any ideas?Does the positive connect to the ignition lock or the negative?any advice would be appreciated | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You can get the original electrolock coils but they aren't cheap. Chevs of the 40s has them on occasion. Kanter says they have them.
| | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | Will the one I have work and how does it connect? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jimferrar,
On these Chevrolet rigs, coil positive (+) will go to the key switch (ignition lock) and negative (-) will go right down to the distributor.
Stuart
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have never worked with one of these ignition systems, but if the '46 system is like the '42 system, it has a reversing switch in it, between the coil and the distributor: http://chevy.oldcarmanualproject.com/shop/1942/42csm1228.htmIf this post is out in left field, I'll delete it. | | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | I'm still having problems starting. My truck does not have a reversing switch. Does it need one to start? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jimferrar,
If the distributor has been rigged properly, you don't need a polarity reversing switch for it to run. The general consensus is that you DON'T want that switch on the truck...they are a pain in the butt!
Stuart | | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | do you know what the proper setup for the distributor is?I just want to make sure that this is not the problem | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Lets diagnose the problem instead of guesing at it. First make sure there is current to the pos. side of the coil when you turn the key on.Then make sure the points open & close as the engine turns over, Use a test light or a jumper wire & touch the pos. term to ground momentarally. If that is good take a screwdriver & open the points shorting them to ground off & on. put the high tension wire comeing out of the center of the coil close to a ground. Each time you break the circuit in the points a small spark should be at the screwdriver & a fat blue spark should jump out of the coil. If it does & it doesn,t spark as you turn the engine over then the points are dirty or burnt. If you dont get any spark at the points there is a bad connection somewhere or the condenser is bad. Make sure the wires connected at the points are not turn & shorting to ground. This should give you something to work with & let us know what you find & we can help some more.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jimferrar,
Don't forget your other post on this problem!
Stuart | | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | well after replacing plugs plug wires condenser points rotor button coil It still wont start. I took the wire off of the coil and I'm definately getting spark. I have checked the carbuerator and I am getting gas, but it still wont start. The positive battery cable and the ground are a little ratty. could this rob enough juice to keep it from starting. It's really frustrating because it sounds like it really wants to but just cant make it to start all the way. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Good grounding is everything on a 6v system. Fix your battery cables before you try anything else. 12V cables are not heavy enough, most are 4ga.. You'll need a 1 or 0 ga cable on both positive and ground. Make sure your ground connections are clean at both ends of the cable.
| | | | | Joined: Feb 2008 Posts: 156 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 156 | Others might disagree, but I would either pour a little gasoline down the throat of the carburetor (careful!!) or spray some starting fluid in it. My '51 is little-used, and when I try to start it every couple weeks, and it doesn't start, I wonder whether I've broken something in the course of other work. So I give it an ounce of gas in the carb, and assuming the battery is charged, the connections are clean, the choke is closed, etc., etc., it starts up.
DJ '51 Chevy 3104 1/2-ton 216
