0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#4521 02/01/2005 3:02 PM
Will the 5 lug drums from 39 1/2 ton work on my 55.1 1/2 ton. I am swapping rear ends and don't mind the current brake system. I have found a fellow bolter with the above mentioned parts and I am not sure if those parts would work.
Any help is appreciated.
-Chris
Chris 1955FirstSeries
Anonymous
Unregistered
Anonymous
Unregistered
Chris, I'm 99% sure that the '39 1/2 tons ran 6 lugs. In fact I think even the Chevy cars back then had six lugs. You better check those parts out carefully to make sure what they are.
The only way the '39 has 5-lug hubs is if someone converted it. But its likely the parts that converted a '39 can also be adapted to convert the '55 1st.
One caution. '36 Chevy cars had a one-year-only 5-lug bolt pattern. It doesn't fit anything else, and you'll want to be certain you're getting 5 x 4.75 hubs and not something else.
