2 members (Gdads51, 1 invisible),
92
0
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 8 New Guy | | New Guy Joined: Jun 2007 Posts: 8 | I have a 54 chevy in good condition..with the original engine..... I use the truck on weekends to get around town and was considering replacing the engine with something a bit newer...... Looking more for reliability, not really a purist, just really want to drive the truck regularly.
I'm not a mechanic so I'll have to search one out.. Is there a remanufactured engine that anyone would recommend....? I want to maintain the shift (floor).... Do I have to consider updating to 12 Volts........? Any idea's of rough parts/labor cost....? Does there have to be much modification to accomodate a newer 6cyl?
Thanks, | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd suggest you start by looking for a shop that will do a swap, make it clear to them what you want to achive, and then consider seriously the motor they recommend. And bring that recommendation back here for critique.
I suggest that approach because I feel the success of a swap depends a lot on who does it, and choosing your mechanic in this case is your toughest problem.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the engine just needs to be freshioned up & you have a good shop you have confidence in I would do a minor o-haul.If not I would pull it & send it to a rebuilder like Jaspers & have it remanufactured. Changing to a more modern engine can be very expensive to have done & the results are not always satisfactory unless you can do it yourself. Going to 12 volts is a good idea for a driver. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How much do you want to spend?
A 235 engine can be a very reliable engine (1954-1962). Is your engine giving you troubles? What sort of reliability problems are you having?
The original 6v starting systems can be just as good as 12v starting systems, if you have large enough battery cables, good grounds, and a good starter. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Another consideration besides those listed above is the title. Your truck is pre '55 so it may have been titled using the engine number. If that is the case & you change the engine you won't have the "vin" that is on your title anywhere on your truck. I'm not saying don't do it but be aware that you may have issues later on especially if you want to sell it.
| | | | | Joined: Jul 2008 Posts: 6 New Guy | | New Guy Joined: Jul 2008 Posts: 6 | Recently purchased 250 6-cylinder Chevy engine, number next to distributor reads FO522TAB. What do I have? Year? Truck or car engine? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | just remember that the engine you have as been a reliable engine in the days when people were not as concerned about maintenance i have seen some that have over 90,000 miles with out a oil change just added when need and also no filter. just freshen it, is. i have the original one in my 54 and drove it daily for 20 years back and forth for work. drove it yesterday and a guy asked me i was on the way to a show, i said no just running errands. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
