0 members (),
234
9
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Hey all, I've got a bunch of plug wire, and a bunch of ends, and some questions. This stuff was free to me, but I'm not sure how to use it. The ends I have are all the same, and it seems to me that I should have different ends to connect into the dizzy. I realize that pictures would be helpful here, but no working electric camera. Am I correct in thinking I need some sort of "tool" to strip the wire, and instal the ends? I figured someone here would no doubt have done this a million times. Thanks; Christopher. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't think it takes anything special to strip the ends, just a careful touch not to nick the conductor part. The trick is properly crimping the ends without the right tool.
Whether it takes something different on the distributor than the plugs depends on your distributor cap. Some do some don't.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Do you have points or electronic ignition? Solid core wire or supressor wire? Electronic ignitions don't work with solid core wire, except Pertronix Ignitor I.
If you never stripped and crimped ignition wire, get plenty of length of wire and a few extra terminals. Takes a little practice to get them right and clean. There are straight and 90 degree terminals and boots.
Crimping tools come for different size wires. 7mm is the most common. Even if you use a multi-purpose crimping and stripping hand tool, always use a vice when crimping that size wires.
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Perfect, I'll scrounge around for a crimping tool, and then make up a set of spare wires, to put with the other spares under the seat. Thanks. Christopher. | | |
