8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45144 05/20/2002 1:10 AM | Joined: Dec 2000 Posts: 14 Member | | Member Joined: Dec 2000 Posts: 14 | Can anyone tell me how the oil filter mounted on this engine? I have a NOS Fram but the mount is set up for an Olds. I believe it hangs off the intake manifold. Also not sur how the lines hook up to the engine. | | |
#45145 05/20/2002 5:40 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | You're correct. It was mounted to the intake manifold with two U bolts.
On my '48, the pressure line comes off of a T towards the back of the block and feeds up to the top of the filter with a metal line. Then there's a rubber return line that goes down to a pipe near the front of the engine. | | |
