8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Adding air to my 235 and not 100% happy with options for mounting the alternator. Thinking about mounting my alternator off the frame next to trans with a pulley at the 'U' joint. vs cluttering up the inline 235 motor. Compressor can mount where the generator would be. I've seen this in a rod magazine some time back and thought it was very trick. Any input would be appreciated either way, pro or con on this idea.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The alternator would only run when the truck is moving, so whan you're sitting at a stop light, you will be draining the battery.
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Look at the size difference between the alternator pulley and the crankshaft. The alternator needs to turn several times engine speed, so unless you're running interstate speed all the time, powering the alternator off the driveshaft isn't an option. I have run small alternators mounted on the transmission tailshaft, turned by a big pulley welded to the slip yoke, but that was on a dirt track race car, just to keep the battery charged during the race. We started out every night with a fully-charged battery, and probably didn't run 20 miles all night. Jerry
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think you would be better leaving the alternator where GM put it and if you want a compressor, put it on the other side like GM did on their trucks with air brakes. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | All good points, I was planning to run a larger pulley on the yoke and smaller on the alt. spinning it faster. I realize that stop and go traffic would be a killer but my drives are mainly at highway speeds. Just think it would be something to try and very easy to undo. Thanks | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I don't see it as a bad idea at all. They switched from generators to alternators because the gen didn't charge as much at idle. Alternators do. Alternators were not designed to run primarily at high rpm's.
I've been giving some thought to doing the opposite approach, on a none stovebolt application. CCOT AC systems cycle the compressor off and on periodically. How inconvenient would it be with the AC pump driven off the driveshaft? In light traffic the pump wouldn't be off that long at most lights. This has got to be crazier than the alternator.
'67 GMC 3/4 292 4spd
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Does anyone have factory specs. for this GM alternator, ie. output at various rpms????? | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Mad electrical offers these numbers for the internal regulated 63 Amp 10SI.
The available output at a 680 rpm idle is 35 - 40 Amps
rpm required for maximum output is 1275 - 1325 rpm
Remember that alternator output current is determined by the needs of the battery. Voltage is controlled at a constant level by the voltage regulator. They consider the typical alternator output to be about 3-5 Amps while driving down the road with no lights or AC. It doesn't matter if you have a 30Amp or a 130 Amp alternator. That's all the battery needs.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You could switch to an electric AC compressor, and run a bigger alternator.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Richard, Your idea of the remote AC compressor vs alternator may be a better solution. I'm just thinking easier to run longer wires vs. ac hoses. Would there be any problems with the longer hoses required for such a system or the frame mount in general? There appears to be a good mounting location at the frame. Thanks Jim | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Jim - Check my alternator location: http://www.joefuchs.net/gallery/gallery.php?eventid=5Go thru the pictures until you get to the underhood shots of the alternator. It works great in that spot and the A/C compresor is in the generator spot. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Where do you find the electric AC compressors. I've googled them but can't seem to find anything. | | |
