| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 13 New Guy | | New Guy Joined: May 2008 Posts: 13 | came across a 27 or 28 pickup today in a dirt floor lean to all my trucks are 35 so want in need to know is where is the data plate and are there ways to tell the difference
lady i talk to today said it was her grandmothers and she thinks she was 10 when it was parked there about 30 years ago
truck looked good other than the drives door was open and would not shut and the upper section of the front windshield had fell out and was laying on the passenger fender in two pieces also there was want i think was a turn signal mounted to the back of the cab that you fliped up
so how can i tell want year it is thanks
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I believe at least for 28 Chevy cars that was the first year for front brakes. If trucks followed the same rule than that is an easy to tell.
I have a 28 car, but I forget where the tag is, probably on the firewall, engine side.
Also, the 28 had plenty of room under the hood and a deep fan shroud, this in anticipation of the new 6 cylinder in 29. I don't think 27's have that much extra length under the hood?
Grigg | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Look for the data plate on the passenger side of the seat.It will be nailed on, If it's still there. The model LM 1927 truck and early 28 Model LO truck had rear brakes only. Mid year they went to 4 wheel brakes on the LP model. The 27 and 28 trucks had the same hood. The cars as Grigg pointed out had a longer hood in 1928. Cleon | | |
