| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45056 08/10/2002 12:13 AM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | I recently found out that a motor I acquired is a 261. It was a good running motor when it was removed a couple years ago and I put fresh oil in the crankcase and marvel oil in the cylinders.
I really want to get this motor in my truck, but the L-6 is an entirely different animal to me. I was thinking about just replacing the gaskets and seals in it and giving it a fresh coat of paint. I don't have the $$$ for a shop rebuild, but have just acquired some machine tools to check all the tolerances, etc. What do you all think.
I will probably want to pick your brains with more questions about this one later. Thanks...Tom. | | |
#45057 08/10/2002 7:30 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | From one who's been there. Stick the engine in your truck. If you open it up you will figure that you have to rebuild, even if you can't afford it. Be sure to prime the oil pump and run it like a new engine until the rings seat.
Fred 52 3600 69 C-10
#45058 08/10/2002 11:01 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I totally agree with Fred T. on this matter
