0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#45056 08/10/2002 12:13 AM
I recently found out that a motor I acquired is a 261. It was a good running motor when it was removed a couple years ago and I put fresh oil in the crankcase and marvel oil in the cylinders.
I really want to get this motor in my truck, but the L-6 is an entirely different animal to me. I was thinking about just replacing the gaskets and seals in it and giving it a fresh coat of paint. I don't have the $$$ for a shop rebuild, but have just acquired some machine tools to check all the tolerances, etc. What do you all think.
I will probably want to pick your brains with more questions about this one later. Thanks...Tom.
#45057 08/10/2002 7:30 AM
From one who's been there. Stick the engine in your truck. If you open it up you will figure that you have to rebuild, even if you can't afford it. Be sure to prime the oil pump and run it like a new engine until the rings seat.
Fred
52 3600
69 C-10
#45058 08/10/2002 11:01 AM
I totally agree with Fred T. on this matter smile
