| | | Forums66 Topics128,051 Posts1,055,711 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Hi all, I just bought a Big Bolt from my neighbor. I decoded the vin via Vin Buster and found that it is a 1.5ton Made in October, 1947
Vin is: 21QK-J 1278
Now, I would consider this a 48 Truck by todays standards of manufacturing, but the title says 47 (Or so my neighbor says, he's still looking for it.) and the QK says 47.... So what is it?
Also, what specifically should I ask for when I call GM for the resto kit? I called and they told me there was "nothing available".... I gave em my Vin and Year (47) and they wanted a model... So I told them 1.5 ton truck... They needed a model name, so I told them Loadmaster....... They found nothing. I decided instead of confusing the poor girl, I'd ask here what to ask for specifically.
Thanks!!
-Matt
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your resto kit will be based on your V I N. They will tell you what it is. | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Yah, this gal couldn't do it though.... She needed me to tell her the model.
-Matt
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | They have never been able to tell me anything on the five Chassis serial numbers from any of my trucks I think they just want it for their records. I once asked for one fro my 1951 Chevrolet brub and received one for a 1951 sedan. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | October is about model change time, so its hard to say what Chevy thought it was.
A '47 will have a 4-speed with a little lever that allows it to go into reverse. A '48 will have a 4-speed with no little lever.
Take a look at the firewall. If the flat surfaces are completely flat its a '47. If the flat surfaces have some embossed areas that look like someone laid some metal strips on the stamping machine, its a '48.
VIN Buster says the wheel base is 161 inches, that makes the model a 4400. And if the wheelbase really is 161 and not 164, that's one more indicator its a '47 and not a '48.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Ok, yes, the tranny shift has the little lever... I wondered what that was all about......
I'll check the firewall and wheelbase in a little bit.
Also, where would the body code plate be at in this truck? I found the vin plate, but was trying to find the body code plate with color codes, etc....
-Matt
| | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Ok, checked the firewall. It's smooth, or at least as smooth as any firewall I've ever seen
The Wheelbase is 161"..... So I guess it's a 47 for sure now.
-Matt
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Okay, you got me curious.... what is a resto kit? Is that like a build card? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Ok, got my Resto kit ordered. Got a different person at GM and it took them a bit, but they found it and it's on it's way. When I get it, I'll get scans to send over to the Old Car Manual project.... Since they don't have 47 resto kit images.....
Thanks for the help.
-Matt
| | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Okay, you got me curious.... what is a resto kit? Is that like a build card? See here: http://www.stovebolt.com/techtips/GMRestoPak.htmThey explain it way better than I could.
-Matt
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | oh great, I live in Canada. According to the info on the link about resto kits the Canadian GM people charge and can't search further back than 1977. Looks like I'll have to talk my brother in law into doing it from the states. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Also, where would the body code plate be at in this truck? I found the vin plate, but was trying to find the body code plate with color codes, etc.... There won't be one. Or at least I've never seen one on an old truck like these. Having a '47 is cool. I have a '47 COE. The problem with a '47 is you have to have the knack to shift that transmission. If you are like me and switch between manual transmission vehicles all the time, you may find it difficult to remember when you're in the crash box and when you're not. I'm solving the problem by hot rodding mine.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Yes, in Canada you're kinda stuck....
So I take it that the 47's had un-synchronized trannies then?
It's all moot as I'm gonna stick a 6BT cummins diesel and GM 4L80E converted to a powershift.....
-Matt
| | | | | Joined: Sep 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 75 | From 1948 through 1953, light duty Chevrolet trucks were introduced in January of the specified model year so a truck produced in October of 1947 would almost have to be a '47 model. '54 trucks were introduced in December of '53 and 1st edition '55 trucks were introduced October 28, 1954. 2nd edition '55's were introduced March 25, 1955. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | "QK" is a '47. A '48 would be "RK". | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Cool enough. Thanks everyone!
I also found some old registration papers clipped to the visor that date from 67/68.... Has the title number on it so it should make my job easier there....
-Matt
-Matt
