1 members (Erniegp), 47 guests, and 3 robots.
Topics128,055
Posts1,055,782
#449296 09/05/2008 3:43 PM
Hey guy's I have a 51, 235 in my 52 1/2 ton. It runs great,(other than the lifter than bleeds down overnight). Question is, why is my exhaust so sootie. It is black and powdery. I can almost sweep it up. It doesn't matter what I do to the mixture and timing. Any ideas? The truck doesn't smoke but does leave a black deposit on the floor.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
GEC52 #449300 09/05/2008 4:03 PM
Glenn,
The soot (dry) is the product of a rich fuel/air mixture. This means too much fuel which is probably a carburetion problem.
I would do the basic things first which would be to make sure your choke is coming completely open, your power valve is open to manifold vacuum and the float adjustment is dead on. Check your air cleaner too, it must not restrict any flow.
Stuart
atomarc #449508 09/06/2008 2:19 AM
Thx Stuart,
I'll check the mixture. The chock is manual and I know it is full open since I've checked it many times. You got me on the power valve though. What and where is it? I haven't checked the float since I bought the carb new. I'll look up the specs on that. Thx.
Glenn,
1952 Chevy 1/2-Ton
GEC52 #449512 09/06/2008 2:30 AM
Glenn,
The power valve is a doo-dad inside the carburetor that gives it a little extra fuel when vacuum is low. This would be when you are climbing a hill or have your foot in it, so to speak.
The base gasket has holes that be aligned under a little passage in the base of the carburetor...sometimes the phenolic spacer has a small notch too. The passage inside the carburetor must be open to the inside of the manifold. I think checking the float level would be good insurance too.
Those are a few of the things that could cause a rich mixture. Maybe someone will be along with more things to check out. Good luck.
Stuart
atomarc #449931 09/07/2008 2:45 PM
Thx Stuart,
Now I know what your talking about. I'll pull the carb to make sure that I didn't put the insulator on backwards. I do know that the notches are at the top.
GEC,
1952 Chevy 1/2-Ton
GEC52 #450153 09/08/2008 5:32 AM
Once you soot up an exhaust, it takes a while for it to clear out. The best way to check your mixture (shy of a gas analyzer) is to read the plugs.
Paint & Body Shop moderator
