2 members (Otto Skorzeny, 5 Window 9434), 130 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#44985 12/13/2002 9:20 PM
Just bought this truck, sorry if I sound stupid, but I have the frame in the garage and want to upgrade the driveline for highway speeds. I gather that I need a T-5, are they all the same? What do I need to bolt this up to the existing bellhousing? Can I use a solid driveshaft? Would I still need to change ring & pinion? Mine is column shift- is that a problem? I really appreciate any help, I'm new to this!
#44986 12/14/2002 4:48 AM
Changing the ring/pinion, with one of the units from Patricks would help. I think it changes your 4:11 to a 3:55. That will drop your engine rpm down at highway speeds. smile
